S1 Elan Rebuild - My Story
I bought a 1964 Elan S1 last summer and drove it for a few months while reading everything I could on the forum and the many books I had. The car had been through a cosmetic restoration and partial mechanical, but lots of things were wrong and not up to my standards. Clearly the PO and the shop that worked on it didn't know the full details of an Elan and it required much needed attention (motor mounts on backwards, my friend Bruce pointed that out right away).
The big items where an engine that smoked white smoke all the time and smelled like oil (although didn't burn any oil or use any water) and the front and rear suspension needed replacement as the car bounced around like it was only on springs. Then all the little stuff which is too much to list but drove me crazy regarding the way things were done.
So I had a major decision to make. Do I restore to "factory spec" or "enhance" the car to have a true "fast road" sports car with a great period look. I agonized over the decision and in early winter decided to rebuild the car using primarily 26R spec with the goal to make it comfortable for the road (I don't expect to track this car). The hunt was on for all the parts I would need (some of them "unobtainable") and determining how far to go with the rebuild. Typical for me, I bit the bullet hard.
Sourced a twin cam engine that had been in storage for many years and shipped it to a race engine builder on the East Coast who builds twin cams for historic race cars. My direction was to build a reliable engine with very good mid-range torque and produce about 160HP at the crank on 93 octane pump gas. No crazy redline spec so the OEM crank stayed in (after magna flux) with new rods, pistons, cams, bearings, etc. etc. Details to follow after the dyno in a couple of weeks.
Spent the entire winter sourcing parts and slowly filling my garage (and emptying my wallet) with everything I thought I would need for a rebuild.
Recognizing that the increase in HP had a downstream effect (I've build a couple of track cars) I decided to use Tony Thompson Racing (TTR) parts for the drive train and rear suspension. All the usual things, rebuild the differential with new bearings, seals, hub shafts, drive shafts, braces, etc. Bought TTR's fast road exhaust system and had the header ceramic coated.
Also ordered selected parts from RD Enterprises (Ray is only an hour drive from my house) and Dave Bean in CA (Thanks for all your help Ken). Seems I got one of the last crash pads from Type 26 before they stopped making them. QED supplied the larger airbox for better breathing. Bought a new reproduction radiator from Coolex Heat Transfer in the UK.
The big turn was acquiring a 26R chassis a couple of weeks ago that had been in storage since new that was already black powder coated and located only a couple of hours from my house. Thanks Bill!
With the engine builder giving me a time frame to completion in a couple of weeks, it was time to get the rebuild going.
Yesterday my friend Drew and I removed the body from the chassis. Neither of us had ever done this before so after reading as much as I could figured it would take is 8 1/2 hours from start to finish. It took us 8 hours with a 45 minute lunch break included. Now that I have done this I could probably do it in 6 hours next time (or even less).
What did I learn so far?
The design of the chassis is amazing and pure mechanical art.
There are 18 bolts that hold the chassis to the body (NOT 16).
The drilling of new holes in the chassis and tapping some of them is going to require patience and exact placement of the body.
Mice like the drive shaft tunnel as a nesting place
Here are a few photos from the day:
Engine bay before disassembly
I made large pads for my lift to support the body
Up in the air for work to be done
Engine bay ready for body removal
Jack stands and 2X4 to support chassis while lifting body with two post lift
This also allowed us to be underneath the car to remove chassis bolts
Interior was a bit torn apart to get at the chassis bolts
Separated from the body (after we found the chassis bolts behind the dash!)
Time for a beer!
Time for a beer!
Last edited by Certified Lotus on Sun Aug 09, 2020 10:59 am, edited 11 times in total.
Glen
65 Elan S2 - 26/4055
72 Europa - 74/2358R
69 Elan S4 - 45/7941
64 Elan S1 - 26/0379
06 Elise - Track pack
Hello Glen, sounds like you're going to do a really good job, and you've achieved in under 9 hours what has taken me four months. I look forward to reading updates on how everything goes and how the finished article will go. I won't try to keep up with you, either in build speed or car speed, but hopefully you will inspire me. Time for a beer!
If something is worth doing well.................................................... it's well worth undoing
- JC33supreme
- JC33supreme
Day two was focused on power washing the chassis and removing the engine and gear box. It was a nice day so Drew and I took the whole project outside and worked in my driveway.
After the power wash it became evident this chassis had been repaired a couple of times. There were a couple of areas that had been welded and a few areas (like the motor mount flanges) that had cracked again even though they had been welded.
The chassis wasn't rusted anywhere. But it had a couple of cracks and a number of locations where it had been jacked up and the frame was dented. I doubt this is the original frame. If it is, this car spent its entire life garaged and serviced by unknowing mechanics who lifted the car under the chassis in multiple points due to the areas that were dented.
The most surprising discovery was the right rear spring perch was rubbing against the sidewall of the tire. The left side was very close, but not rubbing. I'm changing to narrow springs and perch plates so this will not be an issue on the new build.
Well, there were clearly some stress points during the life of this car. Glad I am replacing it with a 26R reinforced chassis.
Some Photos from the day:
Power washing the chassis, suspension, engine & gear box
Nice and clean for inspection
Brazed welds
Brazed motor mount flange, but cracked again
Rear spring perch rubbing against the tire!
Getting ready to remove engine & gear box
Needed to remove shift lever to get engine out
Success!
Test fit of new chassis
Removing parts from old chassis to prep for transfer to new chassis
Brazed welds
Success!
Last edited by Certified Lotus on Tue May 26, 2015 1:54 am, edited 3 times in total.
Glen
Glen,
Great photos and write up. I look forward to watching your progress.
Love your HUGE spacious driveway. It is bigger than my house!
Regards Daniel
Regards Daniel
Currently driving!
1994 MX-5
1990 PRB (Lotus 7 replica)
1985 Elfin Fvee
1968 Lotus 51 FF
1963 Alfa Spider 101 series
1963 Elan S1
1994 MX-5
1985 Elfin Fvee
1968 Lotus 51 FF
1963 Elan S1
- Karter7
Glenn,
Is that a NJ license plate I see? Where are you located? I'm in Holmdel.
- Jentwistle3
Here is the time lapse video I shot of the work done on Saturday to remove the body from the chassis. Used a GoPro camera set to shoot 1 frame every 5 seconds. The 8 hours of work ended up taking 4 minutes on screen (I removed the lunch break where nothing was happening).
https://youtu.be/6kHOBrl8gKQ
Glen
Boy, do you guys work fast. But it seems you kept on knocking your heads together; must have hurt. By the way, you definitely slowed down after lunch.
Good effort!
Good effort!
Visit www.lotuselansprint.com
trw99 - Coveted Fifth Gear
Dang..........it's the perfect Denny's combo plate..............An early BRG, a guy that takes pictures.....and a sweet shop.......................
My fav post in a long time.
"Be Polite, Be Professional, But have a plan to kill everyone you meet"
General "Mad Dog" James Mattis United States Marines
- cal44
Thanks for all the kind comments and interest in my rebuild.
I've owned and worked on British sports cars since I was 16 years old. My parents never got to use our one car garage because one of my sports cars was always in it with the engine or trans out. They were very happy when I went off to college and the chain hoist was no longer needed
These days I am a very lucky man because my wife has never complained about building a bigger garage for my hobby or the tools needed to complete my projects. She is happy that I stopped track days, that always worried her.
The rebuild of my ?lan is pure joy to me. Can't wait for the next step of removing all the suspension parts, rebuilding the rear differential, painting the bits that will make it look nice and the reassembling the entire car. I expect to have everything done in a couple of weeks. Hopefully
Last edited by Certified Lotus on Tue May 26, 2015 1:55 am, edited 1 time in total.
Glen
Glen,
Awesome! The best part is the support you are / will receive from the Lotus Community. The guys on this Forum are absolutely the best. Feel free to contact me if you ever have a question or need a part.
Frank
Frank
Famous Frank
67 Elan Coupe
66 Elan S2 SE
65 Elan S2
65 Elan 26R
69 S2 Europa
06 Elise
67 Barracuda
67 Elan Coupe
66 Elan S2 SE
65 Elan S2
65 Elan 26R
69 S2 Europa
06 Elise
67 Barracuda
Famous Frank - Fourth Gear
[quote="Certified Lotus"]
My S4 was the same, when rebuilding the rear hubs there is a "correct" sequence for assembly of the Hub Bearings, Spacers and Shims, the most common problem is that the previous owner has rebuilt the rear hub and inserted the inner bearing the wrong way round, this moves the wheel 1/4" closer to the Spring Perch and hence the tyre rubbing the upright. It is worth checking the Workshop Manual to ascertain the correct sequence.
PeterExpart
New Forest National Park
Hampshire UK
Hampshire UK
- peterexpart
