Differential - fitting problems
I have just taken the diff. out of my '70 Elan S4.We followed the workshop manual instructions. It took 3 solid hours of pushing and pulling, including a considerable amount of time bending back a piece of chassis and unbolting the piece of angle iron that stretches across the top of the housing and is secured by a central bolt. This bolt seemed to be a lot longer than it needed to be(40mm). I understand it was a standard fitting on Sprints, but what does it DO, and is it really necessary? If I have to re-it it I'm going to chamfer off the corners so that it goes in easier, but I can't see that it serves any purpose. Thanks for any answers.
- tyasman
Stops the fragile "ears" being broken off the rear diff housing when you give it some "wellie"....keep it there...Colin didn't add anything that wasn't necessary...
From memory the manual is quite clear ? the diff cannot be removed or replaced with the brace fitted.
The real problem I found when removing the diff was that the lower end of the casting near the input flange fouled the chassis ? and only cleared with a bit of ?controlled? brute force. To aid refitting I ground off the protrusion level with the rest if the casting and it went back with minimal effort.
The other aid was to cut a slot in the brace tube so that with the bolt partly pre-assembled the brace can be easily fitted when the diff is in position. Do not reduce the length of the bolt.
Brian Clarke
(1972 Sprint 5 EFI)
(1972 Sprint 5 EFI)
bcmc33 - Coveted Fifth Gear
The manual also properly states to install from the lefts side.
This is important - I just refitted mine and fought like crazy from the right side - there was NO way it was going in. So I read the manual and it says slide in from the left.
Guess what - it WAS that easy - slide it in from the left (drivers side for us in the US / passenger side for the UK crowd). It went right in.
Good Luck
Good Luck
- Briggs1
Briggs, you're absolutely right. It's a little like one of those Chinese puzzles...at a certain strange twisty angle from the correct side, it pops in and out with ease. It took me a while to figure...and having to resort to reading the manual!
Last edited by Elanintheforest on Thu Jul 31, 2008 9:47 am, edited 1 time in total.
The diff in my S2 won't come out without the help of a big bar and some prying. I tried it every which way and it needs to be squeezed out and back in again. It could be that someone has put a jack under the chassis at some time and put a slight bend in it but my friend's Plus 2 was exactly the same when we did the diff on that.
Peter
66S2
Peter
66S2
Lincoln62 - Second Gear
On a car that has had a donut failures the diffs go in an out quite easily....
Kidding aside I have never had a problem removing one. If I recall the process - I rotate the nose to about 2 o'clock ( using drive shaft flange as hand and as if you were looking down) Then pull the left lower ear clear of the platform on the Left side . nose goes up and then the unit slides out..
George
George
- cabc26b
Users browsing this forum: No registered users and 45 guests
