Engine weight
PostPost by: bcmc33 » Sat Nov 11, 2006 9:42 pm
What is the weight of the engine and transmission in an Elan Sprint? I need to hire a small crane set-up and must be sure it is the correct capacity.
To know the lifting points will also be useful.
Brian Clarke
bcmc33
PostPost by: patrics » Sat Nov 11, 2006 10:30 pm
Hi Brian,
Engine approx 100kg
Gearbox 38kg
patrics
PostPost by: tower of strength » Sun Nov 12, 2006 3:05 pm
I used a 1 ton folding hydraulic jobbie, not sure if it was a Clarke or Sealey one, they all seem to be pretty much the same, however the forward legs just about fit between antiroll bar/shockabsorber mounts and you may have probs in this area with a "baby" Elan. My advice would be a block and tackle and a static frame work. This how I intend to re fit my engine. Also the hydraulic effort didnt lift that high and needed manual assistance to get over the nose cone!
hope this helps
tower of strength
Users browsing this forum: CG901 and 66 guests
