Ride height
PostPost by: 661 » Sun Aug 05, 2012 10:05 pm
Having adjusted the rear spring platforms recently and this problem developing, I today measured the sill heights after some weeks of spirited driving and see the rear height has settled to 5 3/4 ", which is probably contributary to the problem. I've bumped it up today, unloaded, to 6 1/4" at the rear and found I only ground once on my bumpy testing circuit!. I've bought some new exhaust brackets and will fabricate a support at the front of the silencer if still grinding.
Graeme
S4 SE
S2 GTS
Caterham 420R
Sold - Peterson JPS Exige
User avatar
Coveted Fifth Gear
Coveted Fifth Gear
PostPost by: abstamaria » Wed Aug 08, 2012 2:24 am
I will post two photos I took yesterday, using ride-height guides I fashioned many years ago.
The manual says block the suspension at 6.125" front (15.5cm) and 6.00" rear (15.2cm) ?beneath the front lower wishbone fulcrum and beneath each rear chassis leg adjacent to the wishbone pivot and NOT touching the
pivot.?
L1020660.JPG and
I am assuming that ?beneath front lower wishbone fulcrum? means the bottom edge of the lower front wishbone. Do you agree?
Andy
PS: Those are TTR wishbones, which are optimized for a lower ride height. I am wondering if I should shift to standard wishbones now.
abstamaria
Third Gear
Third Gear
PostPost by: abstamaria » Wed Aug 08, 2012 2:30 am
Here is the rear arm.
L1020662.jpg and
I am assuming too that ?beneath each rear chassis leg adjacent to the wishbone pivot and NOT touching the pivot? is the lower chassis flange. Do you agree?
By the way, the chassis flange is the same height off the floor as the rear sill corners, so 6? (about 5.2mm) from the rear sill should be correct. I wonder though whether the front sill corners correspond to the 15.5mm at the fulcrum.
Andy
abstamaria
Third Gear
Third Gear
PostPost by: rgh0 » Wed Aug 08, 2012 11:21 am
All of the Lotus height measurements are based on the standard tyres to set the ride height. What was standard becomes the question when. 520 x 13, 145 x 13, 155 x 13 were all used during the life of the Elan.
I would set height to what works for your usage and then check the all the wheel alignment parameters versus specifications at the height you select.
User avatar
Coveted Fifth Gear
Coveted Fifth Gear
PostPost by: abstamaria » Wed Aug 08, 2012 1:50 pm
You're right, Rohan.
I figure the diameter for a 145R15 tire is 56.2cm and for a 155SR13 58cm, an 1.8cm difference.
I have 450M CR65 Dunlop racing tires on. Their specified diameter is 56cm, so I'm going to use the manual's specifications to start - or perhaps 1.0cm lower.
Best,
Andy
abstamaria
Third Gear
Third Gear
PostPost by: ecamiel » Thu Aug 09, 2012 11:36 am
For final adjustment, II sugest you check and adjust the corner weights after you have set castor and camber. It makes a big difference in handling and "feel" if you want to drive fast.
Eric
65 S1 Hart
User avatar
ecamiel
Second Gear
Second Gear
PostPost by: abstamaria » Sat Aug 11, 2012 9:29 am
Yes, I'd like to do that, Erik. I'll borrow corner weight scales again as soon as I sort the ride height and recheck alighnment.
Here I am am, checking ride height this morning with my supervisor.
Andy
IMG_0636_2.JPG and
abstamaria
Third Gear
Third Gear
PostPost by: Galwaylotus » Sat Aug 11, 2012 10:02 pm
Considering that the ride height, as Rohan has confirmed, is based on the tyre diameter, I wonder if anyone has measured and documented the difference between the inner and outer suspension arm pivots or other reference points. In other words, the angle of the suspension arm rather than the ride height is what needs to be defined to ensure correct suspension geometry. This has the benefit of remaining constant for various diameter tyres. Anyone have that data? :?:
Mechanical Engineer, happily retired!
'67 S3 SE FHC
See Facebook page: W J Barry Photography
Put your money where your mouse is, click on "Support LotusElan.net" below.
User avatar
Galwaylotus
Coveted Fifth Gear
Coveted Fifth Gear
PostPost by: fatboyoz » Sun Aug 12, 2012 3:24 am
Perhaps, suspension arms parallel with the ground. Works for me, and you can dispense with the tape/rule and fit what ever tyre you like.
Colin.
Galwaylotus wrote:Considering that the ride height, as Rohan has confirmed, is based on the tyre diameter, I wonder if anyone has measured and documented the difference between the inner and outer suspension arm pivots or other reference points. In other words, the angle of the suspension arm rather than the ride height is what needs to be defined to ensure correct suspension geometry. This has the benefit of remaining constant for various diameter tyres. Anyone have that data? :?:
'68 S4 DHC
fatboyoz
Fourth Gear
Fourth Gear
PostPost by: abstamaria » Sun Aug 12, 2012 4:12 am
Yes, I agree. Parallel arms have been the standard and a good rule. The problem is that I have "26R" arms, which have a crook in them (see earlier photo). After I turned 60, the look and stance of a standard Elan have become more appealing to me, so I want to go back to that to the extent I can. I also can't fit 155s on current wheels, which are 6" wide, and of course the old wheels will not fit on 26R hubs.
I may have to switch to standard arms or flop the 26R items. I'll ask Tony Thompson.
Cheers,
Andy
abstamaria
Third Gear
Third Gear
PostPost by: Galwaylotus » Sun Aug 12, 2012 8:11 pm
Thanks, guys. That's what I expected. As regards crooked arms, I would think a line between the inner and outer pivot axes is what should be parallel to the floor. It really doesn't matter what the arm does in between the points. :wink:
'67 S3 SE FHC
User avatar
Galwaylotus
Coveted Fifth Gear
Coveted Fifth Gear
PostPost by: abstamaria » Sun Aug 12, 2012 11:28 pm
Yes, that's the line I have been using as my reference, Galwaylotus. I just wonder now whether the relatively lower damper mounting bolt will restrict damper travel. I'll use the Elan first and see.
I reviewed my journal and found a handwritten note with drawings from Tony Thompson, describing how to set ride height for the lowered A-arms. At the front, he suggests setting the long section of the lower wishbone parallel to the ground. Since the wishbone then bends up to meet the trunnion, that would keep the damper at the same height relative to the chassis, but effectively lowers the chassis.
He ends by saying "if it looks right, it is right!" That was in the late 1990s.
Andy.
abstamaria
Third Gear
Third Gear
PostPost by: abstamaria » Tue Aug 21, 2012 10:44 am
To recap, the manual says block the suspension at 6.125" front (15.5cm) ?beneath the front lower wishbone fulcrum.? I?m not sure if that means that 15.5cm would be the ride height or that the car should settle to a lower ride-height after the blocks are removed.
On the assumption that the standard wishbone arms are straight and that the desired wishbone angle is parallel to the ground, wouldn?t the trunnion bolt then establish the right height for the inboard wishbone bolt? If so, that should be true regardless of tire profile height.
I measured the middle of the trunnion bolt on my car, and it is about 17.1cm from the ground to the center of the center of the bolt. If I took the measurement at the bottom of the wishbone, beneath the trunnion, as shown in the photo, the measurement is 15.5cm.
P1020696.jpg and
I wonder if ?beneath the front lower wishbone fulcrum? means the bottom of the wishbone at the inboard end?
Surprisingly, my trunnion bolt heights are not identical left to right. I wonder why that is.
Andy
abstamaria
Third Gear
Third Gear
PostPost by: ardee_selby » Tue Aug 21, 2012 12:22 pm
abstamaria wrote: I wonder if ?beneath the front lower wishbone fulcrum? means the bottom of the wishbone at the inboard end?
Andy
Andy,
That is how I interpreted it when I set mine. i.e. "Fulcrum: the support about which a lever pivots"
Cheers - Richard
ardee_selby
Coveted Fifth Gear
Coveted Fifth Gear
PostPost by: abstamaria » Wed Aug 22, 2012 5:01 am
Thanks, Richard. "Fulcrum" technically could be the threaded peg or stud on which the lower wishbone rotated, but I suppose one coudn't put a block beneath that. Confusingly, the manual uses "pivot" instead of "fulcrum" when referring to the rear ride height. I'll start with 0.5cm lower all around.
Andy
abstamaria
Third Gear
Third Gear
PreviousNext
Users browsing this forum: No registered users and 15 guests
