Elan drive shaft coupling PCD for S1
The S1 Elan - at least the early ones had a different pitch circle diameter (PCD) for the donut coupling spider bolts from the later S2/S3/S4 cars.
I am having a discussion with a friend on what the difference was. The only reference I can find in in the Robinshaw and Ross book "The original Lotus Elan" which is a little vague but implies it was about 1/4 inch larger.
The later cars PCD was 95mm which implies the S1 PCD was around 100mm.
Does anyone have a early S1 with original drive shafts and have they ever measured the donut spider PCD ?
The PCD of the early Elan's rotoflex coupling is 4 inches, which unfortunately doesn't give the proper preload using the current batch of manufactured rotoflex couplings, but as an engineer at the factory told me a few years ago, "You don't really have much of a choice, now do you?"
Scott In Ohio
26/3795
26/3795
- 65 Lotus
I'm just at the end of the process of converting my donuts to CVs. I had a problem when I put my S1 together years ago as I bought some heavy duty diff output shafts which had the later dimension so I had to mix the two sizes (late and early) when fitting the inner donuts (which made a difficult job even more difficult). I searched for an answer to the early PCD question but I couldn't find one. For the CV conversion I had to make adaptor plates with two different dimensions. I used the 96mm dimension for the late type diff output shaft. I found through a little bit of trial and error on the mill that 100.2mm fitted my early type spiders. I tried 100mm but it wasn't right. The mill was accurate as the 96mm drillings fitted the later type spiders perfectly.
Not sure when the change came about. I had a set of drive shafts from my 1967 +2 and they were the later dimension.
Hope this helps. I'll post the full story of the conversion when it is completed (hopefully later this week).
1964 S1 (Now sold)
- cocky
The smaller dia. was on 26/0538 - late 63.
During the restro 11 years back I converted to the later larger size. I have a doner car - 65 S2. The front disk brake assembly was a smaller dia. than later cars as well, I also changed those to the larger dia disks and calipers. I suspect both changes were done simutaniously at the factory.
The origional factory shop manual does not address the change or differences in any way.
Bill
Bill
Bill - Third Gear
The S1 discs/shafts were fitted into the early S2 cars (S1.5) at least untill 26/3944 and a probably quite a few later.
Here is a pic of some new S1/S2 (early) disc's which I bought to fit to my early S2 although I also made up CV shafts to suit
Some measurements with a micrometer, centre-to-centre between holes in the spider:
"standard" (ie late) spider: 83.0 mm
early spider: 86.8 mm
PCD = centre-centre distance / sin(60) gives
standard: 95.84 mm
early: 100.23 mm
which matches the empirical 100.2 reported above and means it is *not* 4" (101.6 mm).
On the subject of preload and compatibility with later-type donuts, I had always assumed that in fact the nominal donut PCD didn't change, but the smaller diameter was adopted to increase the preload - but that's just a guess.
Paddy
standard: 95.84 mm
early: 100.23 mm
Paddy
1963 Elan S1
paddy - Coveted Fifth Gear
Thanks guys for the quick responses - It never ceases to amaze me that such an obscure question can be answered so quickly
My summary of the data is
late PCD 95.8 +/- 0.2mm
early PCD 100.2 +/- 0.2 mm
The tolerancing is my estimate from measuring up the 4 spare shafts and 4 spare disks I have plus the data given.
The change over from early to late was during the early S2 production and after chassis number 26 / 3944
In a recent post, Gary noted that the early PCD driveshafts were supplied for the first 1000 or so Elans, up to around 26/4027.
http://www.lotuselan.net/forums/elan-f14/rear-axle-t24218.html
I just measured the driveshafts that were on my Elan, 26/4203, when I bought it in 1981 and confirmed that they are the late (95.8 mm) ones, so this provides more definition about the changeover point.
Jon
Jon
- jpt
4027 is Peter's phone number, oops 4109 is the change point according to the Ross and Robinshaw book. Oh well, more misinformation as it becomes available
Gary
Gary
If I were to order a set of your driveshafts for 26/0538 (late 63 production) which I intend to do in the near future, and considering the fact that I may have installed later shafts from my doner car during the last rebuild many years ago which made it work ay the time - I assume that you will need the PCD measurements to confirm correct supply. It has been so long that I am not sure of the spider size except that I changed the shafts to my S2 spares.
I will be lifting it thu the winter (new MaxJax 2 post) for maintenance and can check it out.
Bill
Bill
Bill Rathlef
Vancouver Island, Canada
Bill - Third Gear
