S4 soft top installation - help
PostPost by: Certified Lotus » Sat Jul 16, 2016 10:54 pm
I'm near completion of my S4 rebuild and finally dug out the soft top that came with the car. I hadn't even looked at it until now. It was very dirty and took a couple of hours to clean it up, only to find that I could not figure out why there were so many snaps along the front of it and how the heck do you attach this to the windscreen?
I'm completely stumped. Can someone show me a photo of what the front of the soft top install looks like at the top of the windscreen. What I have makes no sense to me at all.
image.jpeg and
Glen
65 Elan S2 - 26/4055
72 Europa - 74/2358R
69 Elan S4 - 45/7941
64 Elan S1 - 26/0379
06 Elise - Track pack
Certified Lotus
PostPost by: elanfan1 » Sat Jul 16, 2016 11:13 pm
I believe the fixing at the top of the screen is similar through the models. I think you have a non standard 'hood' arrangement there. That aluminium strip fixed to the top of the screen frame should take a flat metal insert sewn into the leading edge of the hood itself, that then friction fits under the aluminium (yours looks too tight). Stupid stoopid question but you don't have a tonneau there rather than a hood do you?.?
PostPost by: gjz30075 » Sun Jul 17, 2016 12:51 am
Exactly. The metal strip on the car should sit proud, by may 3/16" or so, so the leading edge of the hood/top
fits in the gap. No snaps are needed. Time for a new top, Glen.
Greg Z
45/0243K Sprint
45/7286 S3 SE DHC
PostPost by: Certified Lotus » Sun Jul 17, 2016 1:33 am
I thought something was very wrong. Just don't understand as the top fits perfectly everywhere except at the top of the windscreen. No, it's not a tonneau cover. Very strange.
Glen
Certified Lotus
PostPost by: richardcox_lotus » Sun Jul 17, 2016 9:47 am
It also looks like the ''gap' on the windscreen trim has been closed up - looks like more than the normal number of rivets.
So maybe the PO changed things. If you get a standard new hood you may need to recheck the strip otherwise the new one cannot be attached
'72 Sprint
PostPost by: Certified Lotus » Sun Jul 17, 2016 12:02 pm
Can someone show me some detailed photos?
Glen
Certified Lotus
PostPost by: jimj » Sun Jul 17, 2016 12:54 pm
Like this.
Jim
p1010002.jpg and
p1010001.jpg and
PostPost by: Certified Lotus » Sun Jul 17, 2016 1:28 pm
Thanks Jim. That is very helpful.
Glen
Certified Lotus
PostPost by: c.garde » Sun Jul 17, 2016 5:57 pm
Gentlemen,
As can be seen on the 2 pics this hood suffers from the same problem as my recently installed hood, bought from a very well reputed supplier.
The reinforced lip is simply too short to fill the channel. On my hood this leaves a gap of 20mm +,- in each side.
I think every body will be able to imagine the noise coming from these gaps.
This winter ( well it has already started :-( ) I will have to rectify this but it should not be necessary in the first place .
Also the padding in the " ears " is omitted these days , also contributing to the anwanted flute concert.
As Mozart put it : Only one thing is worse than a flute, that is TWO flutes.
I had to buy a replacement because my original hood had shrunk 2 " in lenght.
Apart from this it was still in excellent condition after 40 years, and of far superior quality.
I am considering a rebuild of this and sell the new one.
Best regards Claus Garde
new o
c.garde
PostPost by: William2 » Mon Jul 18, 2016 4:49 pm
I have recently purchased an Everflex hood from Sue Miller. Well made and instead of the original design of a metal strip for the front windscreen fitting they now use a nylon/plastic strip, which seems a good idea.
William2
