Boot flooring
My 1972 +2S has home-made replacement carpet boards for the shelf over the spare in the boot. These sag, although the brackets appear sound. The parts book shows the shape of the left & right 1/2s from the top but gives no indication of underside reinforcement. Should there be a reinforcing (steel) strip running fore & aft on the underside of each ? shelf that connects to the holes in the main support brackets front & back?
I would want to support my luggage in style should I ever leave the garage.
Cheers from rainy Virginia, John
- john122S
The original floor isn't really that good, this is my '73 Plus 2 130/5
The floor is 5.5mm thick, the stiffner to the left is 22mm square and the one down the centre is 31mm x 18mm. The light pieces of wood are what I've added so the floor clears the spare wheel
Hope this helps
Andy
Hope this helps
Andy
- andyelan
I found that the original boot flooring touched the battery terminals. Being plywood there was no electrical short, but I did not like the idea of a permanent mechanical load on the terminals. I added a wooden perimeter frame to the underside of both panels to raise them about 1/2 inch above the original location. Mine did not have the relief I see cut into Andy's panel. This relief is right above the battery.
Russ Newton
Elan +2S (1971)
Elite S2 (1962)
Elan +2S (1971)
Elite S2 (1962)
If you know the basic dimensions you could take Andy's picture above and map it out to a close template. Then refine it. My brother had good results that way with my dash.
- kcrossle
Carlos
You could print out the picture and then scale it up, however, the originals don't fit very well anyway, so you would probably be better getting some card and making templates to suit your own car. Just dont make them such a good fit that you can't get them in and out.
Andy
Andy
- andyelan
I copied this of this site, sorry I can't credit whoever drew it because I didn't make a note of the name.
Hope it helps
Hope it helps
- mikealdren
Carlos A wrote:Thanks Mike. Is that the floor of a Plus 2 trunk, right?
correct.......
and thats my drawing....
posted it on the site about....ooo...5 years ago.....
